07-08-2020 06:31 AM - edited 07-08-2020 06:36 AM
I'm going to design a kintex ulterascale based custom board. I want to use dual stacked DDR4 SODIMM for FPGA, according to following picture.
in Ug583, wrote :
IMPORTANT: Figure 2-33, Figure 2-35, and Figure 2-36 show configurations with multiple DIMMs. To
reduce the effect of SI reflections, always place DIMM #0 on the furthest connector from the FPGA.
DIMM #1, if present, should be placed on the connector nearest to the FPGA .
Now I have a question: what is the meaning of Dimm #0 and Dimm #1 ?
in my design, witch of slot A and Slot B is Dimm #0 ? and witch of them is Dimm #1?
let me know either Slot A should be placed furthest or nearest.
thanks .
07-09-2020 01:06 AM
Please refer to the PCB layout. Find out which is the near connector for DIMM1 and which is the furthe rconnector for DIMM0.
07-09-2020 01:06 AM
07-11-2020 02:37 AM
thanks for your response,
as I understood, dimm #0 and dimm #1 is not assigned to a special connector ,and it depends on what the pcb designer decides. if pcb designer decides that "connector A" be further, then "A" will be dimm #0 and "B" will be dimm #1.
Did I get it right?
07-12-2020 07:25 PM
Yes, that's correct.
