sraza
in appropriate address width I guess
Hello all,
The MIG has designed while creation generated the address width to be something like this
constant ADDR_WIDTH : integer := 29;
-- # = RANK_WIDTH + BANK_WIDTH + ROW_WIDTH + COL_WIDTH;
Now I dont remember where I read and also couldnot find again that since the DDR3 that I am using has only 1 rank,
hence the Rank_width should be ZERO.
Hence the default width created by MIG is 29 while in actual it should be 28.
What if I change the width to 28 by myself, I am not sure if it will positively affect the design as per my need (i.e. without any rank DDR3)
What is the proper rememdy
waiting...!
Shan
gszakacs
Instructor
Instructor
You don't say which version of MIG, but this looks remarkable like Spartan 6, where the address
width is 29:0 (actually 30 bits) regardless of the amount of attached memory.  Normally you just figure
out which bits really control the memory and make sure the others are always zero.  If you don't
hook them up, it might work because undriven nets get grounded during synthesis.  However I would
expect problems in simulation.
-- Gabor
sraza
No this is virtex 6 and MIG 3.8
I have something related to addressing. If you can then I discuss my problem...
I have already discussed in this forum but no one answer till now...
gszakacs
Instructor
Instructor
O.K.  are you sure you have correctly configured the core for the device(s) you are using?  It would
seem that ADDR_WIDTH should be generated based on the configuration (device type, number of
ranks) that you gave the customizer.
What memory device are you using?
-- Gabor
sraza
I am using MT41J256M16EIDT from micron .
and this device I made throught he custom part option since it was not orignally present there.
It has 1 rank hence for one rank, 15 bit row addres, 10 bit Col address, 3 bit bank address it makes 28 bit address.
and I am pretty much sure I made the correct configuration. since I ran the example test as well with the DDR3 part as well...
hengel
I also think there is some inconsistency for the generated ADDR_WITH. These are bit widths of different SO-DIMM parameters fed into MIG 3.91/ISE14.1 for Virtex-6 and the generated ADDR_WIDTH paramerter:
ModuleSizeRowColBank#RanksADDR_WIDTH
MT4JSF6464HY 512MB 13 10 3 1 27
MT4JSF12864HZ 1GB 14 10 3 1 28
M471B5673EH1 2GB 14 10 3 2 28
MT16JSF51264H2 4GB 15 10 3 2 29
MIG creates the same ADDR_WIDTH for modules of different sizes. To my feeling ADDR_WIDTH is one bit to large for single ranked devices: RANK_WIDTH is 1 regardless of module type, IMHO it should be 0 for single ranked ones. The reason why the MIG example design still works for all modules is that the END_ADDRESS value of the TrafficGenerator is by default x"00ffffff" regardless of which module is chosen (at least for the 4 modules listed above).
