Visitor aeley
incorrect parameter in infrastructure.v
When generating a 533MHz DDR3 controller in Mig 3.3, the example project seems to expect an external 533.33MHz clock and a 200MHz clock for iodelay. If I change the 533.33MHz clock to a 100 MHz clock (more reasonable for actual implementation), and adjust the appropriate parameters for the mmcm_adv to generate the right clocks, it breaks. It seems to be due to a parameter being defined incorrectly located in infrastructure.v (line 132 in Verilog and line 140 in VHDL).
localparam real CLKIN1_PERIOD
= (CLKFBOUT_MULT_F * CLK_PERIOD)/
(DIVCLK_DIVIDE * CLKOUT_DIVIDE * nCK_PER_CLK * 1000.0); // in ns
Following the parameters up a level to example_top.v and simplifying, it becomes
= (CLKFBOUT_MULT_F * tCK_f0)/
(DIVCLK_DIVIDE * CLKOUT_DIVIDE * 1000.0); // in ns
 where
CLKFBOUT_MULT_F = PLL VCO multiplier
tCK_f0 = period of the reference clock.
DIVCLK_DIVIDE = PLL VCO divisor
CLKOUT_DIVIDE = output divisor
The MMCM used in the design however takes CLKIN1_PERIOD as the reference clock period and not tCK_f0.
The default values generated by coregen based on a 533.33 reference clock just happen to work:
= (4 * 1875)/
(2 * 2 * 1000.0); // in ns = 1.875
but adjusting for a 100MHz clock does not work:
= (32 * 10000)/
(3 * 2 * 1000.0); // in ns = 53.333
The mmcm_adv primitive thinks the input clock is 18.75 MHz as shown in example_top_map.map:
ERROR:PhysDesignRules:2045 - The DIVCLK_DIVIDE value 3.000000 of MMCM_ADV instance c0_u_infrastructure/u_mmcm_adv is above the Fin / Fpfd value 1.875000, where Fin is the input frequency, 18.750000 MHz, and Fpfd min - max values of 10.000000 - 500.000000 MHz.
 Changing CLKIN1_PERIOD to 10.000 works.
Re: incorrect parameter in infrastructure.v
Yep this does look wrong. You are working in a period environment, not a frequency so you need to invert some parameters.
I do not really see why this parameter calculation is in there, I suspect it is for some legacy reason.
What this parameter needs to be set to is the period of the input clock to  PLL. It has no dependance on CLKFBOUT_MULT_F or DIVCLK_DIVIDE or CLKOUT_DIVIDE. Therefore i would recommend changing:
should be changed to
localparam real CLKIN1_PERIOD = 10.000;
John
The actual clock period is defined in the top level (ie - example_top) "TCK."
This gets passed to the infrastructure module and used as the clk_period. If you want to change clock period, just change TCK value
