07-09-2014 11:35 PM
Hello everyone
Nowadays,I am studying the DDR3 memory controller. I used the MIG to generate a DDR3 memory controller which based on zc706 board and I chose a 8GB RAM module(MT18KSF1G72PDZ) because I only want to do the simulation.
When I do the simulation with example design, everything was ok and modelsim showed "TEST PASSED".
My question is how can I do the simulation without the traffic generator?(I just want to write a simple testbench to check the memory controller)
Watiting for reply
Thank you
jack
07-10-2014 09:37 PM
This question is something design related.
As DDR2/DDR3 is not like SRAM, access can't be done continuously.
Apart fom Write and Read, non data commands like Active, Precharge, Refresh and Zq Calibration will consume clocks at random /periodic intervals, those clocks will add up intermediate delays and user has to wait for the controller to be ready to write/read data.
If you have a data source that continously sends data and you have to store it in DDR3 using MIG you may use FIFO which reduces the effect of delays to some extent.
Hope this helps
Vanitha
P.S:- For questions other than the current Subject please start new threads
07-10-2014 04:50 AM
07-10-2014 06:10 AM
thank you very much Balkrishan
I also searched the internet about how to do the simulation.
And I did the A type that I made a testbench by myself but "ini_calib_complete" never went high.
Also some people said they did the simulation in B type. Just removed the traffic generator and made their own traffic.
I am wondering which simulation type I should use ?
Thanks and Regards
Jack
07-10-2014 08:24 AM - edited 07-10-2014 09:39 AM
To evaluate your board we woruld recommend to use Xilinx Test Bench as it has many configurable features like command, address and data patterns
Once you evaluate the board, you can switch to your traffic, as this is idellay that you want.
To do that genrate example design and comment out traffic gen module and write your own FSM in place of that taking care of commands, write and read timing daigrams given in UG586
No need to modify the test bench, sim_tb_top at all
Let me know if you face any issues
Vanitha
07-10-2014 09:06 PM
07-10-2014 09:37 PM
Hope this helps
Vanitha
07-10-2014 10:33 PM
