JohnsonHu
no DDR cycles as VDMA + DDR simulation
I'm verifying the VDMA + DDR in simulation, though the VDMA + SRAM runs well with the same video source and sink models.
1) Test Block Diagram
The DDR connection is refer to the MIG7 reference design, with 64-bit wide.
"ddr3_model.sv", "ddr3_model_parameters.vh" are included in the simulation.
2) DDR Calibration: It takes about 55 us (the signal init_calib_complete from MIG7 is assert)
3) VDMA -write cycles (axi_s2mm signals)
Q1. Why the VDMA-write transfer stops at the half way of the 4th burst ?   (s2mm_wready turns to be low)
Q2. As there are some wdata transferred, why the DDR3 bus is SILENT after calibration except the refresh cycles  ?
Johnson. FEB.3.2021
JohnsonHu
(update the simulation)
There are several issues if the VDMA stops after some burst among AXI bus.
Please check axi_bresp if the address-map is not valid (for interconnect). If so, use Address Editor to make the address valid.
Besides, it's recommend to select the AXI-interconnect option "debug" for enable AXI protocol checker. It would show any protocol error(s) among AXI-bus !
With these two issues resolved, there are DDR cycles visible.
Johnson
JohnsonHu
Johnson
