jose09621
"Path" of the Automated Trace Matching Checker
Hi, I'm analyzing the AR# 58873 called  "Automated Trace Matching Checker against MIG 7 Series DDR3 Requirements".
I have problems with: " The ISE or Vivado executable path must be defined in the environment variable "PATH"."
Please can someone tell me where I need to change this? I do not know where that  variable PATH is located.
thanks
rpr
Hi @jose09621
Go to windows settings, search environment variable.
Select "path" and click Edit.
Select "New" and add c:/xilinx/vivado/2019.1, here is 2019.1 is example if you are looking 2019.2 then add as c:/xilinx/vivado/2019.2
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
