the io standard selection of sys_rst in MIG IP for Kintex-7 FPGA
When I create MIG IP for Kintex-7 FPGA. The wizard guide me set the location of sys_rst, but no where to set the io standard. After the completion of the ip creation. A XDC file is generated automatically. The io standard is LVCMOS25 in this file. If I modify this as LVCMOS15. The IP is regenerated when synthesis and the xdc file is regenerated, the io standard is LVCMOS25 again. How can I change the io standard?
You can overwirte the IO standard in your top xdc file.
-----------------------------------------------------Please don't forget to give kudos or accept as solution if information provided is helpful.---------------------------------------------------------------------
Hi @greatmaverick
The MIG tool selects an appropriate I/O standard for the input such as LVCMOS18 and LVCMOS25 for HP and HR banks, respectively.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
How to modify the io standard which is set automatically to LVCMOS25 of HR bank?
I should modify the io standard in the xdc associated with the IP and regenerate the IP. If I regenrated IP before the modification, the problem still unsolved. I do not know whether I can overwrite the top xdc, if the setting occurs at 2 xdc file, will the top xdc file prevail? I will try.
