damien-fruleux
upgrade ZCU111 PS RAM
I couldn't find any answer to my question: what is the maximum amount of PS SODIMM DDR4 memory I can install on a ZCU111 ?
Thank you very much
Damien
kshimizu
Hello @damien-fruleux ,
ZCU111 is the -2E device.  From the DS926(page.24), the speed is depend on the rank on DIMM.  Please check you DIMM.
https://www.xilinx.com/support/documentation/data_sheets/ds926-zynq-ultrascale-plus-rfsoc.pdf
As for the density, it is up to 32GB in DS899(page.11).
https://www.xilinx.com/support/documentation/data_sheets/ds889-zynq-usp-rfsoc-overview.pdf
Best regards,
Kshimizu
Product Application Engineer Xilinx Technical Support
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.  Please Give Kudos.
Sk8dzb
For a ZCU111: DDR4 SODIMM – 4GB 64-bit, 2400MT/s, attached to Processor Subsystem (PS).
Is it what you were looking for?
W.
damien-fruleux
Thank you for your answer.
I need to upgrade the 4GB SODIMM DDR4 memory on my ZCU111, because it's not enough for my project.
But I can't found the maximum memory that I can install ?
Damien
Sk8dzb
The DDR4 SODIMM Supports 1333 megatransfers per second – 2666 MT/s.
The RF-ADC supports a maximum sample rate of 4 GSPS with dynamic range and has a signal bandwidth of up to 4 GHz.
If you need more information The ZCU111 XCZU28DR RFSoC PS DDR interface maximum 2133 MT/s performance is
documented in the Zynq UltraScale+ RFSoC Data Sheet.
Also, Other memory interface details are also available in the UltraScale Architecture-Based FPGAs
Memory IP LogiCORE IP Product Guide (PG150)
Hope this helped you.
Keep me informed.
W.
damien-fruleux
I know all these information !
I just need to change the PS 4GB SODIMM DDR4 memory, like you can do with a computer or a laptop.
But i don't know the maximum memory size that I can install : 8/16/32/64 GB ?
It's probably a stupid question, but I don't found the information on documentations.
Damien
kshimizu
Best regards,
Kshimizu
damien-fruleux
Thank you very much !
I missed this information !
Can I have more information about the speed grade ? Do you have a documentation ?
Thank you agin
Damien
