Anonymous
Not applicable
write for ddr3
HI,Everyone,I have a questuon that the data I need can not be read when I write data to ddr3 continuously.Only when app_rdy is deasserted and then pull up(hold app_en high along with the valid command and address value ) ,My need data can be read correctly.Then app_rdy is high continuously ,the read data is unchanged.I think that if the non back to back command and bakc to back command is different ?
Anonymous
Not applicable
Re: write for ddr3 on MIG
I only can read the data in address of 8 and 72 ,I am very confused.
