CLOCK_DEDICATED_ROUTE set to BACKBONE
HI,
i am using mig and pci controller. i set one constraint as follows to avoid one issue related to clock.
set_property CLOCK_DEDICATED_ROUTE BACKBONE [get_nets sys_clk_i]
at the stage of bitstream generation following error appeared,
[DRC 23-20] Rule violation (RTRES-1) Backbone resources - 1 net(s) have CLOCK_DEDICATED_ROUTE set to BACKBONE but do not use backbone resources. The problem net(s) are sys_clk_i.
what i can do for correcting this?
thanks in advance,
Reshma
Re: CLOCK_DEDICATED_ROUTE set to BACKBONE
Hi @reshmaakhil
Which version of vivado are you using?
Is clock port driving sys_clk placed in same IO column as that of memory interface?
Try following the steps from AR https://www.xilinx.com/support/answers/60480.html
If possible upload _placed.dcp located in .runs-->impl_1 location here.
Deepika.
hi, thanks for your response. i followed the same steps, but i had a confusion in the second step, is it a command to be used in tcl console? when i did it, it ended up as an invalid command. so i added it in xdc file and tried to generate bit stream. but error message came as shown below.
[DRC 23-20] Rule violation (RTSTAT-2) Partially routed net - 1 net(s) are partially routed. The problem bus(es) and/or net(s) are sys_clk_i.
[DRC 23-20] Rule violation (RTSTAT-5) Partial antenna - 1 net(s) have a partial antenna. The problem bus(es) and/or net(s) are sys_clk_i.
regards,
Reshma
hi,
i am using vivado 2016.2, here i am attaching the file u asked.
regards,
Reshma
hi,
i was able to do it finally. but it is not cleared, now it showing the error,
one more thing,
when i executed the second step i got the output as
get_property route [get_nets sys_clk_i]
{ IOB_IBUF0 RIOI_I0 RIOI_ILOGIC0_D IOI_ILOGIC0_O { RIOI_I2GCLK_TOP0 HCLK_CMT_CK_IN0 CLK_HROW_BOT_R_CK_BUFG_CASCO10 CLK_HROW_BOT_R_CK_BUFG_CASCO10 CLK_HROW_BOT_R_CK_BUFG_CASCO10 CLK_BUFG_BUFGCTRL5_I0 } IOI_LOGIC_OUTS18_1 INT_INTERFACE_LOGIC_OUTS18 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 NN6BEG0 WR1BEG1 NN2BEG1 NN6BEG1 { SR1BEG1 CLK_L1 CMT_TOP_L_UPPER_T_PLLE2_CLK_IN1_INT CMT_TOP_R_UPPER_T_PLLE2_CLKIN1 } NW6BEG1 NW6BEG1 NW6BEG1 NE6BEG1 NE6BEG1 NE6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 { NR1BEG1 NN2BEG1 SR1BEG1 CLK0 GTXE2_COMMON_GTGREFCLK } NN6BEG1 NN6BEG1 NN6BEG1 NN6BEG1 SR1BEG1 CLK1 GTXE2_CHANNEL_GTGREFCLK }
i couldnt see "You can see the Backbone is used, and see BB referenced in names."
what may be the reason??
thanks in advance.
Reshma
use tcl file attached in forum post
https://forums.xilinx.com/t5/Implementation/Drc-23-20-Rule-violation-RTRES-1/m-p/488764#M9778
Thanks and Regards
Balkrishan
Hi @reshmaakhil
Try the steps mentioned in the following answer record: https://www.xilinx.com/support/answers/54795.html
Vinay
hi,
i followed the steps shown in the link.
but it ended up in the following error,
[Common 17-1300] A message control rule with a rule id of '1' already exists. You can see what message control rules currently exist by using the command 'get_msg_config -rules'. Please try using a different rule id.
what is the meaning of this message? where i can change id?
hi all,
thanks for the support. now bit stream generation completed without any errors. but, a new problem arised. i am using a kc705 board. processor is not detecting my board as a pcie device. what may be the reason?? please help.
regards,
Reshma
Good solution! It can help me to fix the same error in mine project. Thanks a lot!
Add on the topic.
First I fixed the error as described above. It's some kind of shamanic spell. Then I found the cause of the error, at the physical level of the FPGA. The reason of this error was as follows: I used the frequency, fed to the MIG input from the PAD, at another point in the project. When I gave the reference frequency from PAD only to input of MIG's PLL, this error itself disappeared.
