Observer parithyila
DDR reading issue
we are facing an issue while using ddr3 mig on kintex .init calib done signal is going high ,but while reading  the data from DDR3 the we are seening that the same data is repeating with different address.
for example for address 1 ,2,3,4 we are writing the data 1,2,3,4 but while reading the address 1,2,3,4 we are getting the data as 1,2,2,4 .
is there any solution for this issue
i have attached the image
回复: DDR reading issue
Have you tested IP example design on the same board? Any data error?
Observer parithyila
Hi we have tested with example code there is no error but there is error with custom user logic ,pls have a look on the user logic whic i have attached
Please notice the write operation will be issued when app_en=1 and app_rdy=1. Is the app_addr=xxx0h, xxx8h, xx10h, etc for write and read operation?
Observer parithyila
yes, and while writing we are checking for wdf_rdy and we are not reading and writing at the same time. we are writing big chunk of data and then reading it back
Any scope shots on write/read at the failing address?
Observer parithyila
i have attached the image of scope shot
