Visitor painkil
DDR4 64bit with KU5P (PCI Express) pin mapping problem.
I have a problem with PCI Express Gen3 with DDR4 64bit component.
XCKU5P-FFVB676 have 4 HP banks (64, 65, 66, 67)
Because of that I need 2 QSPI (MT25QU01G) to meet pci express booting time limitation time (100ms), I assigned bank 65 with second QSPI memory. (I'll use Tandem PROM)
But when I trying to check pin MIG DRC with 64, 66, 67 bank I got below message.
==> Bank should be assigned in consecutive
Is there any way to meet DDR4 64bit with PCI express fast configuration?
Please help me.
回复: DDR4 64bit with KU5P (PCI Express) pin mapping problem.
Is it possible to assign QSPI memory to bank 64 or 67? Is there any requirement for the DDR4 performance? Any HR banks can be used for DDR4 interface?
Visitor painkil
Thank you for your reply.
Please check my current situation.
1. QSPI Memory to bank 64 or 64.
   - Because of this QSPI memory should be exist in bank 65 because this pin is locked as configuration memory.
2. DDR4 Performance
   - I sould use HP bank, because KU5P-FFVB676 only have 72 HD IOs
  - And I need 20 GB/s DDR bandwidth to store and load from PCI express and zQSFP+ (100Gbps + 64Gbps)
Thank you.
