Observer seu_baikal
How to connect four 16bit DDR3 to xc7a100tfgg676?
Hello Xilinx expert
 Now,I'am design a xc7a100tfgg676 board,I want connect four 16bit DDR3 to FPGA,can I cont fly-by struct ,connect two DDR3's data on bank35,other two ddr3's data on bank 16,all four ddr3's  Address/control singal connect to bank34?
Re: How to connect four 16bit DDR3 to xc7a100tfgg676?
Hello @seu_baikal,
Please look at the Design Guidelines section in UG586 starting on page 192.  There's a link to the latest version in my signature.
The MIG memory interfaces must be within the same I/O column and must be in contiguous banks.
Based on your description of the desired banks in the xc7a100tfgg676 device this is not going to be possible.
Please look at Figure 1-9 in UG475 for the xc7a100tfgg676 bank diagram and you'll see that going between banks 16, 34, and 34 the interface is not in contiguous banks nor is it in the same I/O column.
Here's a link to the latest version of UG475:
https://www.xilinx.com/support/documentation/user_guides/ug475_7Series_Pkg_Pinout.pdf
Additionally if you were to try this pin assignment in the MIG configuration GUI you would see that it is not valid.
Hello @seu_baikal,
Observer seu_baikal
thanks ryana
that's means i can use bank 13,14,15,16 to connect four ddr3?
Hello @seu_baikal,
That's correct.  To get this interface to fit you'll need to use banks 13 through 16.
