Participant andy_lvjing
How to initialize the DDR4 via DDR4 core UI?
 I use the Vidado tool and generated a RDIMM IP , how could the host(FPGA) configure(write and read) the mode registers inside DDR4 SDRAM via the DDR CORE UI (APP_BUS)?
The app_bus is the user interface between FPAG and DDR CORE. and it contain (app_addr[30:0]、app_cmd[2:0])、app_en、app_hi_pri、app_autoprecharge、app_wdf_data[511:0] ...) . the example pattern just write and read the RAM inside DDR4 SDRAM, not write and read mode registers inside DDR4 SDRAM. therefore, I do not which value shall I send to the app_bus.
Re: How to initialize the DDR4 via DDR4 core UI?
You cannot.  The initialization/configuration is done automatically by the MIG core immediately after it comes out of reset and before init_calib_complete asserts.
The settings for the mode registers depend on the configuration entered when generating the MIG IP.
