Wrong Design Clock Frequency calculated in vivado 2016.2 for kintex7
I have a problem generating a memory controller for DDR3 part MT41K1G8SN-125. I want to clock it at 800Mhz to achieve 1600MB/s.
There is no MT41K1G8SN-125 in MIG option, then I used the part named MT41K512M8XX-125 and modified it with custom button (changed row from 10 to 11).
Controller is clocked at 200Mhz (sysclk) and I set the Design Clock Frequency at 1250ps to achieve 800Mhz.
At the end of MIG controller generation, frequency calculated are set to zero:
Controller Options :
   Memory                        : DDR3_SDRAM
   Interface                     : AXI
   Design Clock Frequency        : 1250 ps (  0.00 MHz)
   Phy to Controller Clock Ratio : 4:1
   Input Clock Period            : 0 ps
   CLKFBOUT_MULT (PLL)           : 0
   DIVCLK_DIVIDE (PLL)           : 0
   VCC_AUX IO                    : 2.0V
   Memory Type                   : Components
   Memory Part                   : MT41K1G8SN-125
   Equivalent Part(s)            : --
   Data Width                    : 8
   ECC                           : Disabled
   Data Mask                     : enabled
   ORDERING                      : Normal
Is it a MIG bug ? How can I solve this problem ?
 See above the all report generated :
Vivado Project Options:
   Target Device                   : xc7k160t-ffg676
   Speed Grade                     : -2
   HDL                             : verilog
   Synthesis Tool                  : VIVADO
If any of the above options are incorrect, please click on "Cancel", change the CORE Generator Project Options, and restart MIG.
MIG Output Options:
   Module Name                     : pea_pistis_mig_7series_0_0
   No of Controllers               : 2
   Selected Compatible Device(s)   : --
FPGA Options:
   System Clock Type               : Differential
   Reference Clock Type            : No Buffer
   Debug Port                      :
   Internal Vref                   : disabled
   IO Power Reduction              : OFF
   XADC instantiation in MIG       : Enabled
Extended FPGA Options:
   DCI for DQ,DQS/DQS#,DM          : enabled
   Internal Termination (HR Banks) : 50 Ohms
/*                  Controller 0                       */
   Memory                        : DDR3_SDRAM
   Interface                     : AXI
   VCC_AUX IO                    : 2.0V
   Data Width                    : 8
   ECC                           : Disabled
   Data Mask                     : enabled
   ORDERING                      : Normal
AXI Parameters :
   Data Width                    : 32
   Arbitration Scheme            : RD_PRI_REG
   Narrow Burst Support          : 0
   ID Width                      : 4
Memory Options:
   Burst Length (MR0[1:0])          : 8 - Fixed
   Read Burst Type (MR0[3])         : Sequential
   CAS Latency (MR0[6:4])           : 11
   Output Drive Strength (MR1[5,1]) : RZQ/7
   Controller CS option             : Enable
   Rtt_NOM - ODT (MR1[9,6,2])       : RZQ/4
   Rtt_WR - Dynamic ODT (MR2[10:9]) : Dynamic ODT off
   Memory Address Mapping           : BANK_ROW_COLUMN
Bank Selections:
System_Clock:
	SignalName: c0_sys_clk_p/n
		PadLocation: AC4/AC3(CC_P/N)  Bank: 34
System_Control:
	SignalName: sys_rst
		PadLocation: No connect  Bank: Select Bank
	SignalName: init_calib_complete
	SignalName: tg_compare_error
/*******************************************************/ /* Controller 1 */ /*******************************************************/ Controller Options : Memory : DDR3_SDRAM Interface : AXI Design Clock Frequency : 1250 ps ( 0.00 MHz) Phy to Controller Clock Ratio : 4:1 Input Clock Period : 0 ps CLKFBOUT_MULT (PLL) : 0 DIVCLK_DIVIDE (PLL) : 0 VCC_AUX IO : 2.0V Memory Type : Components Memory Part : MT41K1GDSN-125 Equivalent Part(s) : -- Data Width : 8 ECC : Disabled Data Mask : enabled ORDERING : Normal AXI Parameters : Data Width : 32 Arbitration Scheme : RD_PRI_REG Narrow Burst Support : 0 ID Width : 4 Memory Options: Burst Length (MR0[1:0]) : 8 - Fixed Read Burst Type (MR0[3]) : Sequential CAS Latency (MR0[6:4]) : 11 Output Drive Strength (MR1[5,1]) : RZQ/7 Controller CS option : Enable Rtt_NOM - ODT (MR1[9,6,2]) : RZQ/4 Rtt_WR - Dynamic ODT (MR2[10:9]) : Dynamic ODT off Memory Address Mapping : BANK_ROW_COLUMN Bank Selections: System_Clock: SignalName: c1_sys_clk_p/n PadLocation: AA10/AB10(CC_P/N) Bank: 33
Re: Wrong Design Clock Frequency calculated in vivado 2016.2 for kintex7
I didn't see this issue in 2016.4,can you try this?
In 2016.2 is this only the GUI or do you see the values being set wrongly in the generated hdl files too?
Satish
I just upgraded my project to 2016.4 as you asked, but same problem.
I don't look into hdl files generated, but the final project doesn't work properly (Frequency of ddr3 is 200Mhz instead of 800Mhz).
Ok I installed the new vivado version 2016.4  and upgraded my design.
To upgrade the mig component I deleted it and re-instatiated.
Now I have the right frequency in parenthesis :
Design Clock Frequency : 1250 ps ( 800.00 MHz)
But if I re-launch the MIG configurator by double-clicking on module in «options for controller 0 - DDR3 SDRAM» I have a wrong value at the bottom of window memory details:
Memory Details: -1.07374e+09Mb, x8, row:16, col:11, bank:3, data bits per strobe:8, with data mask, single rank, 1.35V, 15V
And the report display wrong frequency again :
Can you attach the mig.prj and xdc files
Also have you simulated or tested the example design generated in 2016.4 and still seeing issue's?
Satish
I found the main problem: The Clock option was not displayed in Memory Options configuration menu as you can see on screenshoot above:
The only solution I found is to use another computer with windows 64bits and install vivado 2016.4 on it...
But the ddr3 size problem remain on windows in controller options :
Memory size should be 8Gb and not -1.07374e+09Mb.
I attached mig.prj and xdc file in message.
Kudos: 766
Solutions: 1,009
Hi @martoni
Can you please share the vivado 2016.4 IP XCI file too?
Deepika.
Kudos: 766
Solutions: 1,009
Hi @martoni
Thanks for sharing the XCI file.
I am able to reproduce this issue (incorrect density details shown in MIG IP) in vivado 2016.4 on windows-7 machine. However I dont see this issue in vivado 2017.1 (internal build) on windows-7. This issue will be fixed in our upcoming release 2017.1.
Deepika.
I just installed the 2017.1 and I confirm that bug is fixed.
