Visitor davee
Aurora 64B/66B RTL Implementation
Hi.
I am wondering if anyone has synthesised and implemented an Aurora core for
an Ultrascale device using the RTL code instead of .dcp files. (Vivado 2016.2)?
I have tried to do this but I am unable to synthesise the fifo_generator_v13_1_1 component
that is used within the Aurora IP. This is because it uses encrypted IP and I get the
following error:
ERROR:[Synth 8-5809] Error generated from encrypted envelope.
This is when I use the encrypted files provided for synthesis:
fifo_generator_v13_1_vhsyn_rfs.vhd
fifo_generator_v13_1.vhd
If I do not provide these files, then I can get a synthesised design that has
blackboxes for fifo_generator_v13_1_1 components, but these then cause the
implementation to fail?
I need to know how I can either synthesise fifo_generator_v13_1_1 or
how do I replace the blackbox during implementation.
(I should mention that I can successfully synthesise/implement the Aurora
core using .dcp files, however I want to be able to modify the RTL design, hence the
need to be able to build from RTL.)
Visitor davee
Re: Aurora 64B/66B RTL Implementation
Thanks for your reply zheny.
I have now solved the problem by generating .dcp files at the level in the code hierarchy, for the modules
that incorporate  the fifo_generator_v13_1_1 module. In the Ultrascale Aurora core, fifo_generator_v13_1_1 gets
used in modules user_defined_name_fifo_gen_master and user_defined_name_fifo_gen_slave. In my naming convention
the modules are aurora_64b66b_12lane_fifo_gen_master and aurora_64b66b_12lane_fifo_gen_slave. I have generated
.dcp modules for these modules; aurora_64b66b_12lane_fifo_gen_master.dcp and aurora_64b66b_12lane_fifo_gen_slave.dcp.
This now allows me to synthesise the individual RTL files used in my design, and use the above .dcp files during implementation.
I now do not need to use the top-level Aurora aurora_64b66b_12lane.dcp file to build my design, and now have the ability to
edit/synthesise the RTL if required.
If you have no need to edit the RTL code, and can use the Aurora core generated by IP Catalog, then I would recommend that the top-level .dcp file provided by the tools is used.
Could you try to set the file to the following library?
1 blk_mem_gen_v8_3_vhsyn_rfs.vhd        blk_mem_gen_v8_3_3
2 blk_mem_gen_v8_3.vhd                        blk_mem_gen_v8_3_3
3 fifo_generator_v13_1_vhsyn_rfs.vhd     fifo_generator_v13_1_1
4 fifo_generator_v13_1.vhd                      fifo_generator_v13_1_1
Visitor davee
