Visitor tharvid
Aurora 8b/10b configurations
Hello!
I am using Aurora 8b/10b and Kintex 7 with the following settings:
Lane width: 4
Line Rate: 5
Refclk: 125
Duplex
Framing
I have a some questions:
1. Can I change the AXI frequency so it doesnt use the refclk frequency? I want to connect it with a 200 MHz clock used in an other device.
2. When generating the example design i get some configurations that seem wrong when i look in documentation (PG046 etc.) What is correct?
  * DRP_CLK is set to 50 MHZ
  * INIT_CLK to 200 MHZ (shouldnt this be less than ref_clk?).
  * RXOUT_DIV and TXOUT_DIV is set to 0 which is not allowed. If i change this it works. If i generate the IP with default settings this does not happen. Is this a known issue?
3. I want to use the same ref clk to 4 Aurora IP. Is there a guide on how to do this?
Thank you
/Thomas
Scholar samcossais
Re: Aurora 8b/10b configurations
I am doing the same thing. I use Aurora 8b10b v10.0.
There are quite a lot of weird things done in the example design to be entirely honest.
The aurora_8b10b_0_support_reset_logic.v does not look correct to me (gt_rst_sync cannot deassert because the GT RESET signal it produces reset the source of its synchronization clock...)
Even in the core itself, I've just looked for a few minutes and already found some very basic bugs.
For instance in aurora_8b10b_0_rx_startup_fsm.v line 610 :
    if (RX_QPLL_USED == "TRUE" && TX_QPLL_USED == "FALSE")
    else if (RX_QPLL_USED == "FALSE" && TX_QPLL_USED)
that I believe should be replaced by :
    if (RX_QPLL_USED == "TRUE" || TX_QPLL_USED == "TRUE")
    else if (RX_QPLL_USED == "FALSE" && TX_QPLL_USED == "FALSE")
if QPLL used
    -> assert QPLL_RESET
else if both QPLL are not used (which should mean that then CPLL is used)
    -> assert CPLL_RESET
Scholar samcossais
I know Aurora is a free IP but this looks like some more verification should be needed...
Or maybe Xilinx should make it more simple. All these reset and board debug signals everywhere look a bit messy to say the least. In my case I just need a free and ready for use GT interface and I expected Aurora to be this. Last time I used it (with an older version), I already had problems with the reset and I had to correct a few things in the code after failures in hardware.
This time I already have problems in simulataion. I don't need that many debug functions and I don't use any push button or anything like that so please keep it simple for the user.
