Auto-Negotiation Vector value for 1G/2.5 Geth PCS/PM in XAPP1305
   I am wondering what is the correct value for the Auto-Negotiation Vector (PG047 v16.1 Table 2-40).
   In XAPP1305, the an_adv_config_vector[15:0] is driven by a constant which seems to be set the wrong way:
   xlconstant_3 in the bloack diagram is set to have a 16-bit width with a 100001 value, which is obviously out of range (no warning in BD validation anyway). Should this value be set to b100001 or what else value is expeceted to be?
Luca
Re: Auto-Negotiation Vector value for 1G/2.5 Geth PCS/PM in XAPP1305
Recommended is vivado tools 2018.1 & petalinux 2018.1 but you can use 2018.1 BSP to PS_EMIO_ETH_1g design with 2018.2
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Constant width is 16 and you can write value 55297.
Pratap
Thanks @rpr!
I have tried to set this value in my XAPP1305 ps_emio_eth_1g project with Vivado 2018.2, but it still doens't work.
Please let me know if you have some clue or patch for xapp1305.
Luca
XAPP1305 latest release tested with vivado tools 2018.1 & petalinux 2018.1
Pratap
Hi @rpr,
    I have ported the PS_EMIO_ETH_1g design to 2018.2, by still using the 2018.1 BSP as Petalinux-create starting point.
    It worked fine.
    @rpr , Is my procedure correct?
Luca
Pratap
