How to swap XAUI lanes in FPGA?
Hi !
I use Kintex-7  XC7K410TFFG900 bank117 for XAUI.
In my PCB i have XAUI lanes connected like this:
lane 0 -> X0Y10
lane 1 -> X0Y8
lane 2 -> X0Y11
lane 3 -> X0Y9
As i understand XAUI core demands them to be like this to work properly:
lane 0 -> X0Y8
lane 1 -> X0Y9
lane 2 -> X0Y10
lane 3 -> X0Y11
How can i fix it in Verilog?
Re: How to swap XAUI lanes in FPGA?
I think i found a better way in PG053, p.92. I just changed corresponding GTXE2 numbers. Don't know if it works yet as i found another issue with my PCB.
set_property LOC GTXE2_CHANNEL_X1Y8 [get_cells -hierarchical -filter {NAME =~ */
gt_wrapper_i/gt0_<CompName>_gt_wrapper_i/gtxe2_i}]
set_property LOC GTXE2_CHANNEL_X1Y9 [get_cells -hierarchical -filter {NAME =~ */
gt_wrapper_i/gt1_<CompName>_gt_wrapper_i/gtxe2_i}]
set_property LOC GTXE2_CHANNEL_X1Y10 [get_cells -hierarchical -filter {NAME =~ */
gt_wrapper_i/gt2_<CompName>_gt_wrapper_i/gtxe2_i}]
set_property LOC GTXE2_CHANNEL_X1Y11 [get_cells -hierarchical -filter {NAME =~ */
gt_wrapper_i/gt3_<CompName>_gt_wrapper_i/gtxe2_i}]
You can map the transceiver parallel data correctly in the block file before going to the core as a workaround.
Satish
