Visitor tstrickland
SGMII over LVDS in Artix 7 eye monitor maintenance period
In the <>_gpio_sgmii_top.v file generated as part of a SGMII over LVDS implementation using the 1G/2.5G Ethernet PCS/PMA or SGMII IP core, the eye monitor is enabled periodically after initial calibration. The period starts when the previous eye mon is done, and it ends when any bit in the 24-bit eye_mon_timeout register is set. This means a new eye mon will start immediately after the previous one is done. Is that the intended behavior? It seems odd to implement a 24-bit counter that never counts above 2. Should it restart on &eye_mon_timeout instead of |eye_mon_timeout?
always @(posedge clk104) begin // Periodically enable eye monitor
  if (!eye_mon_done) eye_mon_timeout <= 24'h000000;
  else               eye_mon_timeout <= eye_mon_timeout + 1'b1;
end
always @(posedge clk104) eye_mon_timeout_r <= |eye_mon_timeout;
