Visitor bizertinno
Signal REM_US signification in CRC ip
Hi all,
I'm working with coregen with crc wizard. When running simulation scenarios for  the crc32 ip with isim, I found that verying REM_US signal value affect the crc data_ds which is the result. I have read the data sheet ug189 where signals are well explained but I m still confused with REM_US exact role, can any one tell me what REM_US does exactly ?
Thanks all
Re: Signal REM_US signification in CRC ip
The REM signal is used the number of valid bytes in the last packet of the frame.
So if your lenght of the frame is not a multiple of the datawidth this signal is used to indicate the valid bytes in the last packet.
So depending on this signal as the total number of bytes input to the core vary and so the CRC and data out also varies.
Hope this answers your query.
Satish
