Unidirectional 10G-Ethernet
I was hoping someone really familiar with the TEMAC and 10G-Ethernet core could answer this question:
I notice that when using 1G or 2.5G Ethernet over fiber (with the TEMAC core), I can disconnect the receiving fiber, and data can still be sent.  I assume this means there is no link-establishment process.
I was wondering... is the same possible with the 10GEMAC core?  I have noticed that transmit does not inherently work when the RX fiber is disconnected.  Is there a way to bypass link-establishment?
Thank you,
-Kenton
Re: Unidirectional 10G-Ethernet
HI
You can set  Fault Inhibit bit to 1 in the 10G MAC configuration to sent data on the TX irrespective of RX link status.
Satish
I think you need to do the functional simulation to confirm it. Just create an IP core example design.
Maybe the core TX side keeps working without RX side.
If not, you can just assign some constants to IP core RX signals and make it believe that RX side is linked.
Are you using the 10G PCS/PMA core, with auto-negotiation and/or link training? Not an expert, but I think you can turn these off via MDIO. Or just re-generate a simpler core...
HI
Satish
Thank you all for the excellent and quick feedback.  Inhibiting Faults (MAC Register 410) allowed me to force unidirectional communication.
As a note: I was using the 10G Ethernet Subsystem, which implements the PCS/PMA core.  No auto-negotiation.
