aurora core unstable lane up
I've generated GTP seperately for aurora 8b/10b protocol on 3 Gbps and 150 MHZ refclk.
I'm having issues with lane up and channel up. lane up is de-asserted and chennel up is never high.
It looks like the rxreset is triggered because of missing SP sequence.
and on the TX side the generate SCP is never asserted. This is using the same example design and jsut replacing the GTP cores.Aurora8b/10b is configured for simplex single lane 4 byte.
Re: aurora core unstable lane up
Facing this in the simulation and using aurora example tb and designs (replaced GTP)
Is this with Simplex? if Yes, can you assert reset on Simplex Tx and check if Simplex Rx has channel up asserted.
