error in receiving group mac address messages in ethernet with temac
i am communicating with PC and vertex 5 Temac.mac address of the pc has been set as 01:02:03:04:05:06.as this is a group address i.e multicast address,i am not able to receive the data in PCB.if change the MAC address to 00:02:03:04:05:06 i am able to receive the data.i tried puting the  mac address in general address filter also and enabling the extended multicast but no success.is there any driver code for multicat mode.
thank you
Re: error in receiving group mac address messages in ethernet with temac
thank you for your reply..i got solved...i added that group mac address to one of the general address register and i enabled the multicast option..i am using the example code given by xilinx for ltemac on a custom board.thank you
hi @joginder200109,
can you let us know what is IP core your using and the PCB board is it custom board or evaluation board, if the evaluation board then what is the board number and also how are the connection are made on the board .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
