Petalinux 2019.1 built error
hi
i take error while build petalinux.  i don't understand from this error. would you help me.
$ petalinux-build -x mrproper
$ petalinux-build
[INFO] building project
[INFO] generating Kconfig for project
[INFO] silentconfig project
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating user layers
[INFO] generating kconfig for Rootfs
[INFO] silentconfig rootfs
[INFO] generating petalinux-user-image.bb
INFO: bitbake petalinux-user-image
Parsing recipes: 100% |##########################################| Time: 0:09:38
Parsing of 2777 .bb files complete (0 cached, 2777 parsed). 3812 targets, 163 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#######################################| Time: 0:00:10
Checking sstate mirror object availability: 100% |###############| Time: 0:01:12
Sstate summary: Wanted 875 Found 700 Missed 350 Current 0 (80% match, 0% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: device-tree-xilinx+gitAUTOINC+73e546e312-r0 do_configure: Function failed: do_configure (log file is located at /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.do_configure.28772)
ERROR: Logfile of failure stored in: /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.do_configure.28772
Log data follows:
| DEBUG: Executing shell function do_configure
| MISC_ARG is -hdf_type hdf -yamlconf /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/device-tree.yaml
| APP_ARG is -app "device-tree"
| Using xsct from: /opt/pkg/petalinux/2019.1/tools/xsct/bin/xsct
| cmd is: xsct -sdx -nodisp /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/dtgen.tcl -ws /opt/pkg/petalinux/2019.1/Plate_demo/build/../components/plnx_workspace/device-tree -pname device-tree -rp /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/git -processor ps7_cortexa9_0 -hdf /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/deploy/images/plnx-zynq7/Xilinx-plnx-zynq7.hdf -arch 32 -app "device-tree" -hdf_type hdf -yamlconf /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/device-tree.yaml
| INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
| CRITICAL WARNING: [Hsi 55-1608] VERSION option is not used in file /opt/pkg/petalinux/2019.1/Plate_demo/components/plnx_workspace/device-tree/device-tree/drivers/axi_dispctrl_v1_00_a/data/axi_dispctrl_v2_1_0.mdd. Use 'OPTION VERSION = <>;' && 'OPTION NAME = <>;' in MDD.
| hsi::open_hw_design: Time (s): cpu = 00:00:07 ; elapsed = 00:00:09 . Memory (MB): peak = 730.949 ; gain = 154.699 ; free physical = 117 ; free virtual = 3263
| WARNING: not supported pl_clk:
| Error:plate.dtsi board file is not present in DTG. Please add a valid board.
| ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::generate : Error:plate.dtsi board file is not present in DTG. Please add a valid board.
| while executing
| "error "Error:$dtsi_name board file is not present in DTG. Please add a valid board.""
| ("foreach" body line 90)
| invoked from within
| "foreach override $overrides {
| if {[lindex $override 0] == "BOARD"} {
| set first_element [lindex $override 0]
| set dtsi_file [lindex $override 1]
| ("foreach" body line 2)
| invoked from within
| "foreach i [get_sw_cores device_tree] {
| set first_element [lindex $override..."
| (procedure "gen_board_info" line 7)
| invoked from within
| "gen_board_info"
| (procedure "::sw_device_tree::generate" line 12)
| invoked from within
| "::sw_device_tree::generate device_tree"
| ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
| generate_target failed
| while executing
| "error "generate_target failed""
| invoked from within
| "if {[catch {hsi generate_target -dir $project} res]} {
| (file "/opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/dtgen.tcl" line 38)
| WARNING: /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/run.do_configure.28772:1 exit 1 from 'eval xsct -sdx -nodisp /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/dtgen.tcl -ws /opt/pkg/petalinux/2019.1/Plate_demo/build/../components/plnx_workspace/device-tree -pname device-tree -rp /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/git -processor ps7_cortexa9_0 -hdf /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/deploy/images/plnx-zynq7/Xilinx-plnx-zynq7.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
| ERROR: Function failed: do_configure (log file is located at /opt/pkg/petalinux/2019.1/Plate_demo/build/tmp/work/plnx_zynq7-xilinx-linux-gnueabi/device-tree/xilinx+gitAUTOINC+73e546e312-r0/temp/log.do_configure.28772)
ERROR: Task (/opt/pkg/petalinux/2019.1/components/yocto/source/arm/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2072 tasks of which 1616 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
