jsara
Are there any examples that work for very basic AMP (Use Both Zynq CPUS)
I have tried the XApp1079 bare metal separate apps running on both CPUs on a PicoZed board.  Nothing seems to work from the XApp1079.
I see the new SDK (e.g. 2017.4) includes an option when debugging / running with JTag to specify a .elf file for both cores.  If I write a very simple app( eg a main() that just returns) - 2 copies - one tagged to CPU0 and the other for CPU1, debugging never gets to main and neither core runs (per a video I dont reset the system after the 2nd app is loaded and they both load at distinct dram addresses also per the video).  However if I only try to use CPU0 things work OK.
The original XApp1079 also required a custom FSBL to create a boot.bin that would run on both cores.
Any way, is there any example of something that does ANYTHING with both cores, both cores running bare metal that works?
hbucher
@jsara
 There are several ways but the one you described is simpler. The FSBL is the same.
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xil_io.h"
#define CPU1STARTADR 0xfffffff0
#define sev() __asm__("sev")
int main()
    // Disable cache on OCM
    Xil_SetTlbAttributes(0xFFFF0000,0x14de2);
    init_platform();
    print("Hello World from CPU #0\n\r");
    // Start CPU1
    print("CPU0: writing startaddress for cpu1\n\r");
    Xil_Out32(CPU1STARTADR, 0x2000000);
    dmb(); //waits until write has finished
    print("CPU0: sending the SEV to wake up CPU1\n\r");
sev();
// application logic continues here
cleanup_platform(); return 0; }
hbucher
@jsara This question comes up often so we made a couple of videos
http://www.vitorian.com/x1/archives/587
http://www.vitorian.com/x1/archives/616
jsara
More info:
The attached is a screen capture of the error that happens when launching the debugger with 2 applications (one for each CPU).  It says:
Error while launching program: no targets found with "name =~ "ARM*#1" & jtag_calbe_name =~ "Platform Cable USB II 0000153a82c501"".  available targets:
1 APU
  2* ARM Cortex -A9 MPCore #0 (Suspended)
3 xc7z020
jsara
Those are helpful videos.  BUT THEY ARE WHAT I REVIEWED BEFORE TRYING AMP.  I followed exactly what they said and it did not work.
See my previous post for the error that appears when I try to run with both cores.
Any other ideas.  Does the video example only work with a Zybo board?  I am using a Pico Zed.
Running on CPU0 only works.  Running on CPU1 only does not work.  Running on both CPUs does not work.
hbucher
@jsara Not sure what is wrong. My board shows two cores right away right away after power-on in JTAG mode.
jsara
WOW, that solved PART of the problem.  I swapped to another pico-zed card and the amp demo now works.  The first card I had must be broken.
Here is part two: I would like to now run these two bare metal apps by booting from flash.  Do I need a customized FSBL to get this to work?  The XAPP1079 had a way to add an AMPFSBL to the repository, but that was years ago and does not seem happy here.
I followed the XAPP1079 example (specifying different load values for each .elf file, but did not add their kludge terminating (3rd) dummy .elf file.
Any way, the boot.bin ran the CPU0 app but not the CPU1 app.  In the XAPP1079, they had CPU enable CPU1 by writing the start address somewhere and then firing an event.
Do I need to do something like that in this newer release of the SDK (2017.4)?
Is there an example of getting these 2 elfs to run from a boot.bin file so that I can actually deploy my application from flash?
hbucher
@jsara
#include <stdio.h>
#include "xil_io.h"
int main()
    init_platform();
    // Start CPU1
sev();
jsara
OK, now everything fits together and works.  It works from the SDK debugger, and also from boot.bin.
Would have been nice if they had a revised app note that said you did not need to follow most of the XAPP1079 example - its very obsolete.  The new versions of the SDK streamline the process.
I have all I need (with both videos) and your comments to put in some useful code now.
hbucher
@jsara I added a page to my blog
http://md.vitorian.com/boot-image-zynq.html
