How to boot bare metal first and then Linux using OpenAMP/Libmetal
In the UG1186, all the demo are linux master and baremetal remotes.
I want to make bare metal to be master .
thanks a lot !
HI @DBG
Unfortunately we dont have support for bare metal(RPU) as Master & Linux(APU) as slave.
Let me know exact use case, if you really want to run the Bare metal before Linux it is possible, you can run it from fsbl itself then you can run the Linux.
Thanks & regards
Aravind
Thank you for reply !
Firstly, I want to run both bare metal and Linux on different cores, It doesn't matter if bare metal run on R5 or A53。
Secondly, I want bare metal to run as soon as possible. If I use Linux to boot the bare metal, it's too late.
