Lib Metal Amp Demo - IPI_IRQ_VECT _ID
In the lib metal amp demo there is this line in the sys_init.c file...
IPI_IRQ_VECT_ID  65
Where does the number 65 come from please?
When I run the demo and cat /proc/interrupts, I see the ipi line
has indicated the correct number of interrupts, however it indicates it to be 61, not 65
so I do not understand.
61:    56    0    0    0    GICv2  61  Level  ipi
Can someone please explain what I am missing?
Re: Lib Metal Amp Demo - IPI_IRQ_VECT _ID
Please see page 324 in the TRM.
GIC 65 – Channel 1 IPI – RPU0
GIC 66 – Channel 2 IPI – RPU1
GIC 61 – Channel 7 IPI – PL0 (we are using this for APU, since default APU IPI i.e. Channel 0 is being used by ATF and PMUFW).
