wendelse47155
OpenAMP for FreeRtos and BareMetal on Zynq7020
hey everyone,
I have a short question. Is it possible to run on a zynq720, the core0: FreeRtos and core1: baremetal application?
Like in UG1186 described, and also in older versions, there is always the core0: Linux and core1: baremetal application/FreeRtos. Another old version from 2014 (xapp1079) showed two baremetal processors.
But, does anyone know if "core0: FreeRtos and core1: baremetal" is possible and also knows a good example?
Best regards,
Sebastian
jovitac
Hi Sebastian,
For Zynq-7000 the openamp configuration possible is linux master on core0 (a9-0)and either baremetal or freertos remote on core1 (a9-1). This is the only supported configuration as demonstrated in UG1186
wendelse47155
Ok, so there is no possibility with the openAMP to use FreeRTOS and BareMetal in combination!
But is it possible to use FreeRTOS and BareMetal anyhow in combination (so without openAMP)? Are there other solutions to use it in combination?
Best regards
Sebastian
