javier-rh
OpenAMP in Cortex a53 not available in Vitis 2019.2
Environment
Xilinx Vivado 2019.2
Xilinx Vitis 2019.2
Windows 10
Problem
The option for OpenAmp library in the CortexA53 core is missing in Vivado 2019.2 and in the update.
With the CortexR5 the OpenAmp library works well.
Libraries FreeRTOSLibraries FreeRTOS
Libraries StandaloneLibraries Standalone
The option for select 64bits and 32bits is missing too.
Thank you
Tags (3)
jovitac
For A53, sysroot is used for libraries.
If you have a petalinux project, you will need to include the library in your rootfs
Enable the OpenAMP and libmetal packages with "petalinux-config -c rootfs":
Filesystem Packages --->
   libs --->
       libmetal   --->
         [*] libmetal
       open-amp   --->
         [*] open-amp
Build sdk and package sysroot
petalinux-build -s
petalinux-package --sysroot
Your sysroot will be located here sysroot=/<plnx-proj-root>/images/linux/sdk/sysroots/aarch64-xilinx-linux
You will need to include the sysroot path in your Vitis application for A53
