Visitor claudiofi
Petalinux 2015.2.1 BSP and OpenAMP Framework
Hello to all,
I'm trying to test the AMP configuration (Linux+FreeRTOS) on my MicroZED board and I'm following  the userguide UG1186.
Unfortunatelly in my Petalinux config I'can't see any modules to enable. The Modules options is empty, when I should check that the following modules are enabled.
Modules --->
     [*] rpmsg_proxy_dev_driver --->
     [*] rpmsg_user_dev_driver --->
Do you have some idea about what is the problem?
I'm using Vivado 2015.4 + Petalinux 2015.2.1 + PetaLinux 2015.2.1  BSP ( for z7010).
Thank you in advance,
Claudio
Visitor claudiofi
Re: Petalinux 2015.2.1 BSP and OpenAMP Framework
Sorry...
I'm using Vivado 2015.4 + Petalinux 2015.4 + PetaLinux 2015.2.1  BSP ( for z7010).
Have your tried the BSP that does with 2015.4 as that document UG1186 is new and applies to 2015.4 it seems like?
I see those modules in the components dir of my zc702 BSP.
John
Visitor claudiofi
Thank you so much for your answer... I'm using the BSP 2015.2 because in the avnet website there is this like last bsp for MicroZED board. Now I  try to build a new  petalinux project with the XILINX BSP 2015.4 for ZEDboard and I hope that this work.
Thank you so much,
Claudio
Visitor claudiofi
Does someone know if there is a Petalinux  bsp package 2015.4 version for Avnet MicroZed board, too?
Claudio
Participant wdavidlee
I too am looking for a Petalinux 2015.4 BSP for Microzed.
David
