RPU0 slower than RPU1 when running Matrix Multiplication Demo (UG1186 v2018.3)
Problem: When running the Matrix Multiplication Demo, RPU0 is ~5x slower than RPU1
Question: Is RPU0 expected to be slower than RPU1? or is there a way to increase the speed of RPU0 to match RPU1?
Logs:
RPU0
 # ./mat_mul_demo -d /dev/rpmsg0 -n 10000
 Matrix multiplication demo start
 Open rpmsg dev /dev/rpmsg0!
 Creating ui_thread and compute_thread ...
 Quitting application ..
 Matrix multiplication demo end
	Rounds: 10000
	Duration: 2921ms
 Matrix multiply application end
RPU1 (results)
# ./mat_mul_demo -d /dev/rpmsg1 -n 10000
 Open rpmsg dev /dev/rpmsg1!
	Rounds: 10000
	Duration: 585ms
Details:
We modified mat_mul_demo.c to check for duration.  We also removed printfs, and mutexes.
* Original mat_mul_demo.chttps://github.com/Xilinx/meta-openamp/blob/rel-v2018.3/recipes-openamp/rpmsg-examples/rpmsg-mat-mul/mat_mul_demo.c
* Modified mat_mul_demo.c - attached
Baremetal firmware running on RPU0 and RPU1:
https://github.com/Xilinx/embeddedsw/tree/release-2018.3/lib/sw_apps/openamp_matrix_multiply
Environment: SDK 2018.3, ZCU102
Setup: ZynqMP Linux Master running on APU with RPMsg in kernel space and 2 RPU slaves
References followed
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841990/OpenAMP+2018.2
* https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1186-zynq-openamp-gsg.pdf
Thank you in advance!
Re: RPU0 slower than RPU1 when running Matrix Multiplication Demo (UG1186 v2018.3)
I didn't do 10000 runs but for about 5500, I found it to be pretty compbarable for r5-0 and r5-1
r5-0
real 91m33.500s
user 0m0.814s
sys 0m1.715s
r5-1
real 91m34.505s
user 0m0.791s
sys 0m0.672s
Did you modify RING_TX, RING_RX and the RSC_RPROC_MEM entries in rsc_table.c for RPU-1. The values need to be changed from default for R5-1. Also linker script memory nodes should match what you have in the device-tree
Hello @jovitac ,
Thank you for checking our query.
We have several clarifications.
r5-0
real 91m33.500s
user 0m0.814s
sys 0m1.715s
r5-1
real 91m34.505s
user 0m0.791s
sys 0m0.672s
We would like to ask how to get above values.
Was it executed like this?
[r5-0] time mat_mul_demo -n 5500
[r5-1] time mat_mul_demo -d /dev/rpmsg1 -n 5500
If yes, we would like to confirm if it measures the R5's processing time.
Our understanding is that the `time` tool measures the resource usage of the master application on A53 side, not the remote app on R5.
Is this understanding correct?
Our goal was to check R5-0's performance over R5-1's.
So we modified the demo code slightly to remove the wait time from the A53 master app, and to isolate the processing time in R5 cores. We mentioned the following in the first query:
* Original mat_mul_demo.c - https://github.com/Xilinx/meta-openamp/blob/rel-v2018.3/recipes-openamp/rpmsg-examples/rpmsg-mat-mul/mat_mul_demo.c
Can you tell us if there is a better way to get the processing time in R5?
Yes, we already modified above addresses. We can run both R5-0 and R5-1 firmware concurrently so I think address conflicts were not an issue.
Thank you again for your time.
Yes I did use time. Let me check if we have a different way to measure R5 processing time. I'll also try running with the modifications you have.
