frankxank
Remote processor will not run
I have gotten the echo-test OpenAmp demo to run successfully on our custom board. I have now pulled all the code needed to get remoteproc and rpmsg running from the demo and integrated it into Petalinux, the Linux app, and the standalone app. The output I get indicates that the standalone starts running, but then the kernel crashes. The crash dumps indicate the kernel stops in completely different places each time, indicating runtime memory corruption. I have attached a file showing these errors for 2 runs.
All our tools are v2017.3.
After reading other posts on this forum, I suspect the cause is my linker script. I have edited it to be as similar as possible to the one given for the echo-test standalone, and I have attached it below. I have also attached my openamp device-tree. Could you please take a look at it and see if you see any problems?
One thing I've wondered about is that elf_ddr_0 and rproc_0_reserved overlap, but that is how they are set up in the echo-test demo.
Thanks for any help you can give!
jovitac
To have -DUSE_AMP=1 in your bsp settings. You will need this to disable initialization of shared resources
jovitac
frankxank
You were right. I had a typo in that option.
