XScuGic_Connect() fails with !XIL_COMPONENT_IS_READY ?
I am trying to create a simple "Blinky", FreeRTOS/AMP application. The sample AMP applications like echo_test work so I used those files as a template.
For some reason in my sample XScuGic_Connect() fails:
Xil_AssertNonvoid(InstancePtr->IsReady == XIL_COMPONENT_IS_READY);
The code: XScuGic_CfgInitialize(&xInterruptController, IntcConfig, IntcConfig->CpuBaseAddress);
Is conditional compiled out when USE_FREERTOS is defined.
Where should this be initialized under FreeRTOS?
Tags (3)
Here is the answer.
The AMP sample applications do the low level AMP configuration within a task. This seemed weird to me so I tried to move this into prvSetupHardware(). This seemed much more logical location. What I did not realize is that when the scheduler is initialized it also initializes the GIC. To fix this all the following:
XScuGic_Config *IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
configASSERT(NULL != IntcConfig);
u32 Status = XScuGic_CfgInitialize(&xInterruptController, IntcConfig, IntcConfig->CpuBaseAddress);
configASSERT(XST_SUCCESS == Status);
Before calling XScuGic_Connect() .
Tags (2)
