trimble_pome
libMetal UIO binding
The libMetal documentation states:
The Linux userspace abstraction binds the devices to UIO or VFIO driver. The user applications specify which device to use, e.g. bus "platform" bus, device "f8000000.slcr", and then the abstraction will check if platform UIO driver or platform VFIO driver is there. If platform VFIO driver exists, it will bind the device to the platform VFIO driver, otherwise, if UIO driver exists, it will bind the device to the platform UIO driver.
I am finding the device tree documentation for this opaque to non-existent. Is it possible to get a link to or posting of a valid UIO device tree that uses a libMetal IPI ?
jovitac
You can find the device-tree example in UG1186 Chapter-2 Libmetal, on page 14
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_3/ug1186-zynq-openamp-gsg.pdf
