Visitor eal_roland
petalinux build error - architecture not match - ZCU104
Hello Xilinx-Community,
I want to use openAMP on the ZCU104-Board and followed the manual UG1186.
That means on the processor Cortex-A53 with AArch64-architecture I run Linux and I use as remoteproc the Cortex-R5 with ARM-architecture. I created my app without errors in SDK for the ARM-architecture and copied the generated .elf-file into "meta-user/recipes-apps/myapp/files". Then I modified the .bb-file with the name of my new app.
After running petalinux-build the error "QA Issue: Architecture did not match (ARM, expected AArch64) on /work/aarch64-xilinx-linux/newtryapp/1.0-r0/packages-split/newtryapp-dbg/usr/bin/.debug/newtest.elf [arch]" appears.
But since the Cortex-R5 works with ARM-architecture, I cannot use AArch64 for my pre-built BM-application newtest.elf.
I have attached my app-recipe (with changed ending to be able to upload it). Thanks in advance for your help.
Re: petalinux build error - architecture not match - ZCU104
Can you modify your recipe and put the elf in the lib/firmware directory? Below is an example recipe.
# This file is the rpu-fw recipe.
SUMMARY = "Simple rpu-fw application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://rpu-fw.elf \
S = "${WORKDIR}"
INSANE_SKIP_${PN} = "arch"
do_install() {
	     install -d ${D}/lib/firmware
	     install -m 0644 ${S}/rpu-fw.elf ${D}/lib/firmware/rpu-fw.elf
FILES_${PN} = "/lib/firmware/rpu-fw.elf"
I am also facing the same issue.
How is your standalone application being created in SDK? Have you tried the demo application that we provide?
Select OS platform as standalone, select processor as R5_0, you can select the openamp demo application to start with.
Visitor eal_roland
Thanks for your reply.
The echo-test demo works.
Creation of standalone package:
I create a new application project with "standalone" as BSP-platform. As target hardware platform I create "new hardware project" and as target hardware specification I choose the downloaded file "Xilinx-zcu104-2018.3.hdf".
For the target-hardware processor I select psu_cortexr5_0, and I also use "OpenAMP echo-test" as template.
The BSP-settings show WITH_PROXY=true and as configuration for OS: psu_cortexr5_0 it shows compiler=armr5-none-eabi-gcc and compiler_flags= -O2 -c -mcpu=cortex-r5.
I don't receive any errors when I build the BM-application.
After building I copy the elf-file into the files-folder of my newly created app and modify the .bb-file like shown in chapter 3.3.c of the UG1186.
By the way, I use petalinux version 2018.3 and SDK version 2018.3
LICENSE = "MIT"
S = "${WORKDIR}"
do_install() {
Visitor eal_roland
Thanks, this file helped.
It seems to run after I have changed the rights to 0644 from 0755.
Visitor kwinterer
I see this is marked as a solution but I have the same issue as OP and I can't to make it work.
Where exactly is the lib/firmware directory?
Right now I have a bb file pretty much identical to the example
