Visitor claudiofi
remoteproc: truncated fw
we are using the following configuration:
- XSDK 2015.4
- PetaLinux 2015.4 with OpenAmp framework
In order to use the Zynq core0 like master (o.s. Petalinux) and core 1 like slave with FreeRTOS 8.23
In our tests we have manipulate the "OpenAMP RPC Demo" template and  its elf file is incremented in lenght. When  we launch the command "proxy_app -m zynq_remoteproc" the system answers with these messages:
Do you have some advice?
Thank you in advance,
Claudio
Visitor claudiofi
Re: remoteproc: truncated fw
From the message it seems we are out of memory, but we are sure the memory is enough, we have one GB of ram available for the second core.
Newbie mdct1024
I am having the same issues as described.
Could someone advise some pointers on how to deal with the issues?
@mdct1024
Which version of the tools are you using? Are you trying to run the echo-test as well? Is this for zynq-7000 or zynq ultrascale+?
Newbie mdct1024
I am using:
1) Zynq-7000
2) Petalinux 2015.4
3) SDK 2015.4 (Windows)
4) Yes I am using echo-test with FreeRTOS (ver 8.2.3) for Core 1 and Petalinux 2015.4 for Core 0
After executing modprobe zynq_remoteproc firmware=echo_test.elf on the Linux side, the system prompted about truncated fw which is exactly what is posted in the thread by other users  of this forum.
I am building on top of the echo-test example project provided by the SDK but did not call any functions from the c codes that I have added in the echo-test project.
If I don't include my codes, remoteproc is able launch the echo-test in core 1. Therefore, it seems that remoteproc is not able to cope with loading elf file of larger size.
I am wondering if you could advise some pointers to deal with this issue.
regards
Chow
Have you tried increasing the reserved memory in the device-tree? How much is it getting truncated by?
Hi @mdct1024
Just replying here from the OpenAMP google groups.
I am facing the same issue of yours, but I do not manage to get rid of that "truncated fw" error. Indeed the issue is raised by
remoteproc_elf_loader.c:184
if (offset + filesz > fw->size)
{ dev_err(dev, "truncated fw: [hdr 0x%x] need 0x%x avail 0x%zx\n", i, offset + filesz, fw->size); ret = -EINVAL; break; }
Where the offset (0x30000) does not match the fw->size (0x285f8c in my case). In the following, the debug messages added to check which elf segment causes the error.
remoteproc remoteproc0: Booting fw image lwip_baremetal.elf, size 2645900
remoteproc remoteproc0: registered virtio0 (type 7)
remoteproc remoteproc0: i 1
remoteproc remoteproc0: fw->size 0x285f8c
remoteproc remoteproc0: filesz 0xebfac
remoteproc remoteproc0: offset 0x10000
remoteproc remoteproc0: i 2
remoteproc remoteproc0: filesz 0x108010
remoteproc remoteproc0: offset 0x100000
remoteproc remoteproc0: i 3
remoteproc remoteproc0: filesz 0x0
remoteproc remoteproc0: offset 0x300000
remoteproc remoteproc0: truncated fw: [hdr 0x3] need 0x300000 avail 0x285f8c
remoteproc remoteproc0: Failed to load program segments: -22
remoteproc remoteproc0: Boot failed: -22
By dumping elf content with readelf -a, seems that the segment 3 is causing the issue (i=3) because the Linux module expects to have bigger fw->size or a not null FileSiz for that section.
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  EXIDX          0x208000 0x3e208000 0x3e208000 0x00008 0x00008 R   0x4
  LOAD           0x010000 0x3e000000 0x3e000000 0x28aac 0x28aac RWE 0x10000
  LOAD           0x100000 0x3e100000 0x3e100000 0x108010 0x108010 RW  0x10000
  LOAD           0x300000 0x3e300000 0x3e300000 0x00000 0x21d930 RW  0x10000
 Section to Segment mapping:
  Segment Sections...
   00     .ARM.exidx
   01     .text .init .fini .rodata .data
   02     .resource_table .eh_frame .mmu_tbl .ARM.exidx .init_array .fini_array
   03     .bss .heap .stack
Could you share your solution? Need to patch the automatically generated linker script?
Luca
Newbie eep1nc
Hi Luca
My soln requires modifying the linker script which was generated by SDK.
Add a section something like the following:
.fill:{
FILL(0xDeadBeef);
.= ORIGIN(yourDdrbase) +LENGTH(yourDdr Base) -1;
}> yourDdrBase
This should fill the gaps with oxDeadBeef all the way till end of your firmware.
Chow
Hi Chow,
thanks for your reply.
It works as expected by the remoteproc_elf_loader. The filled section size might be resized though, to reduce the elfsize. Just a little add, the linker does expect the BYTE() command to fill at least one entry in the section.
.fill :
    FILL(0xDEADBEEF);
    . = ORIGIN(ps7_ddr_0) + LENGTH(ps7_ddr_0) - 1;
    BYTE(0xAA)
  } > ps7_ddr_0
Thank you,
Luca
Visitor leopoldo
Hi Luca
I'm using
Vivado SDK 2017.4
Petalinux 2017.4
I'm writing a custom application modified , adding code , in FreeRTOS FW of matrix_multiply demo.
OpenAMP UG1186
matrix_multiply_demo defines
ps7_ddr0_S_AXI_BASEADDR in lscript.ld as :
Base addr 0x3e000000  Size 0x00400000
Adding code to demo, there is error of overflow ddr0
How do I modify system-user.dtsi , openamp-overlay.dtsi and lscript.ld ?
Actually :
system-user.dtsi
/include/ "system-conf.dtsi"
    reserved-memory {
        #address-cells = <1>;
        #size-cells = <1>;
        ranges;
        rproc_0_reserved: rproc@3e000000 {
            no-map;
            reg =  <0x3e000000 0x01000000>;
    amba {
        elf_ddr_0: ddr@ {
            compatible = "mmio-sram";
            reg = <0x3e000000 0x400000>;
    remoteproc0: remoteproc@0 {
        compatible = "xlnx,zynq_remoteproc";
        firmware = "FreeRTOS";
        vring0 = <15>;
        vring1 = <14>;
        srams = <&elf_ddr_0>;
and openamp-overlay.dtsi
    reserved-memory {
        #size-cells = <1>;
        ranges;
            no-map;
    amba {
        elf_ddr_0: ddr@0 {
        vring0 = <15>;
        vring1 = <14>;
Can you please post what error are you seeing?
Visitor leopoldo
I'm seeing this result :
I modified lscript.ld with Size 0x2C1000000 to bypass error in SDK :
The problem is :
truncated fw : need 0x300000 avail ........
Wait for solutions , thanks
Can you increase the stack size and heap size and rebuild your application in sdk?
