Observer ajcurtis84
samples only run once!
I have followed the instructions in UG1186 and successfully built and ran the echo_test using Petalinux v2015.4. The problem is that it only runs once. After exiting the echo_test application, /dev/rpmsg0 disappears. All the device drivers are still loaded. (although the messages when echo_test exists indicates that it should be been unloaded) I am unable to unload the modules manually. Recreating /dev/rpmsg0 does not work either.
Is there a solution?
TIA
Re: samples only run once!
check these links
http://www.wiki.xilinx.com/OpenAMP
https://forums.xilinx.com/t5/Embedded-Linux/Zynq-Petalinux-hangs-on-GPIO-access/td-p/645008
Thanks and Regards
Balkrishan
Observer ajcurtis84
Here is the answer:
The kernel modules must be unloaded and then reloaded each time an AMP application is run. Using "rmmod <kernel module>" does not unload the modules correctly. However using "modprobe -r" does work.
Here are the commands:
modprobe -r rpmsg_user_dev_driver
modprobe
-r zynq_remoteproc
Note: This is applicable for the Zync7000 only.
