virtio1 channel doesn't create for Cortex R5_1
I test echo test with openamp between petalinux and Cortex-R processor.
When I tested cortex-R0,  virtio channel is created on time. but  virtio channel for cortex-R1 in not created.
This in log file about  loading Cortex-Rs openAMP firmware.
for Cortex-R0
[ 26.617687] remoteproc remoteproc0: powering up ff9a0100.zynqmp_r5_rproc
[ 26.625356] remoteproc remoteproc0: Booting fw image firmware-r0.elf, size 788120
[ 26.634659] zynqmp_r5_remoteproc ff9a0100.zynqmp_r5_rproc: RPU boot from TCM.
[ 26.642384] remoteproc remoteproc0: registered virtio0 (type 7)
[ 26.648233] remoteproc remoteproc0: remote processor ff9a0100.zynqmp_r5_rproc is now up
[ 26.650073] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 26.661696] virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x1
for Cortex-R1
root@xilinx-zcu104-2018_2:~# echo start > /sys/class/remoteproc/remoteproc1/state
[ 26.679655] remoteproc remoteproc1: powering up ff9a0200.zynqmp_r5_rproc
[ 26.687281] remoteproc remoteproc1: Booting fw image firmware-r1.elf, size 788008
[ 26.696579] zynqmp_r5_remoteproc ff9a0200.zynqmp_r5_rproc: RPU boot from TCM.
[ 26.704550] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 26.709991] remoteproc remoteproc1: registered virtio1 (type 7)
[ 26.715864] remoteproc remoteproc1: remote processor ff9a0200.zynqmp_r5_rproc is now up
loot at the log file. there are not same, for Cortex-R1 have no "virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x1" message.
and in peta linux, "/dev/rpmsg0" is existed but "/dev/rpmsg1" is note existed,  "/sys/class/rpmsg_user_dev_driver/rpmsg1" in not existed too.
Plz let me know how to create rpmsg channel for Cortes-R1.
Regars.
Shin.
Re: virtio1 channel doesn't create for Cortex R5_1
		test_r51: zynqmp_r5_rproc@1 {
		  	compatible = "xlnx,zynqmp-r5-remoteproc-1.0";
//			reg = <0x0 0xff9a0200 0x0 0x100>, <0x0 0xff340000 0x0 0x100>, <0x0 0xff9a0000 0x0 0x100>;
		  	reg = <0x0 0xff9a0200 0x0 0x100>, <0x0 0xff350000 0x0 0x100>, <0x0 0xff9a0000 0x0 0x100>;
		  	reg-names = "rpu_base", "ipi", "rpu_glbl_base";
		  	dma-ranges;
		  	core_conf = "split0";
//			srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1 &shared_ddr_1 &shared_ocm_ch2 &shared_ocm_ch3>;
//		  	srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1 &shared_ocm_ch2 &shared_ocm_ch3>;
		  	srams = <&r5_1_tcm_a &r5_1_tcm_b &elf_ddr_1>;
		  	pd-handle = <&pd_r5_1>;
		  	interrupt-parent = <&gic>;
		  	interrupts = <0 29 4>;
Please see highlighted - Why is ipi at 0xff350000? Do you plan to use a different IPI for APU. APU uses PL0 IPI. This needs to be 0xff340000 . If you have 2 remoteproc nodes, the core-conf for the 2nd remoteproc node should be split1.
Please see the example openamp dtsi here
https://github.com/Xilinx/meta-openamp/blob/rel-v2018.2/recipes-bsp/device-tree/files/zynqmp/openamp-overlay-split.dtsi
Which version of the tools are you using? Could you please post your device-tree?
Hi~
I use a petalinux 2018.2.2, linux kernel version is 4.14
I attached dtsi file.
Regards.
Shin.
		  	dma-ranges;
