Participant cb_cross
what is proper config for rootfs for libopenamp?
So, collating multiple sources of info including Chapter 3 of UG1186 I was able to get the Matrix Multiply Demo running on my ZCU104 using the pre-built binaries.
Now I want to compile the demo myself so I have a working baseline for custom development.
In the SDK, setting up the R5 half of the demo is simple.  The A53 half of the demo, however is not so simple.  You have to know to grab the C file from here: https://github.com/Xilinx/meta-openamp/tree/rel-v2018.2/recipes-openamp/rpmsg-examples/rpmsg-mat-mul
and not here: https://github.com/OpenAMP/open-amp/tree/master/apps/examples/matrix_multiply
So, the A53 matrix_multiply.c compiles, but fails to link thusly:
Building target: a53_mmult_demo.elf
Invoking: ARM v8 Linux gcc linker
aarch64-linux-gnu-gcc -L"/opt/projects/xilinx/xilinx-zcu104-2018.2/images/linux/sdk/sysroots/aarch64-xilinx-linux/usr/lib" -L"/opt/projects/xilinx/xilinx-zcu104-2018.2/images/linux/sdk/sysroots/aarch64-xilinx-linux/lib" --sysroot=/opt/projects/xilinx/xilinx-zcu104-2018.2/images/linux/sdk/sysroots/aarch64-xilinx-linux -o "a53_mmult_demo.elf"  ./src/matrix_multiply.o   -lopen_amp -lpthread -lmetal
/opt/projects/xilinx/xilinx-zcu104-2018.2/images/linux/sdk/sysroots/aarch64-xilinx-linux/usr/lib/libopen_amp.so: undefined reference to `fw_table_size'
/opt/projects/xilinx/xilinx-zcu104-2018.2/images/linux/sdk/sysroots/aarch64-xilinx-linux/usr/lib/libopen_amp.so: undefined reference to `fw_table'
collect2: error: ld returned 1 exit status
makefile:36: recipe for target 'a53_mmult_demo.elf' failed
make: *** [a53_mmult_demo.elf] Error 1
My question is:  How should I configure my rootfs (`petalinux-config -c rootfs`) such that I don't have missing objects.
And yes, I do `petalinux-build -s` and `petalinux-package --sysroot` after each time I change the config.
Re: what is proper config for rootfs for libopenamp?
The only library you need to build that demo is lpthread. You can also see the makefile that is used to build the demo.
You do not need to set sysroot in this case. Just add the -lpthread library to your C/C++ build settings.
