Visitor sreemoyee8
Analog voltage range for XADC
Is is possible to measeure analog voltage as high as 12V (bipolar) using auxilliary inputs of 7 series xadc???
thanks
Teacher muzaffer
Re: Analog voltage range for XADC
No. The maximum input to VP/VN are 1.5V (including common mode over GNDADC) so you have to divide your input signal to get it to that range.
Teacher muzaffer
Visitor hamidnaghi
What's happen to the XADC if I use opamp that the output might goes up to 3 volts? Is hurt the XADC or it's just saturated?
Hamid
Hi Hamid,
Try not to reply to old threads to ask new questions. Instead make a new thread to ask your question.
To answer your question yes you will damage to the ADC
If you open the user guide ug480: there's a section on over and under voltage. Basically for auxio the max input is allowed to be vccadc+100mv
