Another question for XC7Z030 Configuration
I have a clear idea that Kintex 7 inside XC7Z030 could be configured by PS side.
My question is : Can we leave signal PROG_B and INIT_B on FPGA configuration bank alone?
Many thanks for your answers.
David.
Scholar pratham
Re: Another question for XC7Z030 Configuration
@hg81 You just have to connect pullups to these two pins (4.7K). For PROG_B recommend push-button to GND to enable manual configuration reset.
-Pratham
Scholar pratham
-Pratham
Community Manager
Community Manager
You must not leave these pins floating. As pratham suggested, you have to pull-up these pins via a ≤ 4.7 kΩ resistor.
Please refer to Table 2-4 of http://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf for more details.
Scholar trenz-al
PROG_B button is in most cases useless, the function of PROG_B is software dependant, so asserting prog_b does not always cause the FPGA to be reconfigured.. so a button on PROG_B is potential confusion, as it may not always trigger reconfiguration as it is with normal FPGA's..
Great Answer.
Many Thanks.
Observer mbianconi
Is it safe to connect unused PROG_B with a stiff (<4.7k) pull-up in the 7-series?
I have got recent feedback from HW guys stating that the pin must be low-pulsed at power-up and they suggest a Schmitt-trigger circuit to generate a low-pulse of some unspecified duration only when the board starts up: they state that, if the pulse is not provided, there may be a risk of sporadic FPGA configuration failures.
I have experienced none of these (over a week of power-cycles) and I suspect the problem is down to the configuration settings of their specific test FPGA.
I reckon the PROG_B can be used by an external device if it wants to re-program the FPGA, but there is none in our application and it's absolutely safe to pull-up PROG_B if it's unused.
Am I right?
Observer mbianconi
Just a clarification: our device is actually an Artix-7 FPGA (xc7a50t); but the same should apply to this too as well as to Zynq and SoC. If such a failure existed, it'd mean that the configuration logic can't be relied upon to load the FPGA at power-up.
I tend to think that the pulse on PROG_B just delays the configuration and masks a racing condition with the flash memory.
This can be handled by setting the options the bit-file generation script correctly.
