Artix 7 FPGA with DDR3
In one of design i am using ARTIX-7 and i just wanted to know maximum speed ARTIX-7 FPGA will support for DDR3 Interface.
I am using XC7A200T-2FBG484I Artix -7 FPGA, Hence the speed grade is "-2". that means it will support 800Mb/s DDR3 operation.
Correct me if i am wrong.
Hello @patilpradeep,
This maximum speed depends on the speed grade of the device which you are using. Please check Table 16 (page #13) from below datasheet to knwo the Maximum Physical Interface (PHY) Rate for Memory Interfaces IP
http://www.xilinx.com/support/documentation/data_sheets/ds181_Artix_7_Data_Sheet.pdf
Ashish
Yes that's correct.
Satish
Since the query is answered, feel free to close the thread by marking helpful post as solution.
Ashish
Thanks for the support..
I will close this
I need one more help from your end,
I am feeling that some problem with IBIS model, Bec when i started simulation for DDR3 Interfaces i am able see results are not proper at the receiver.
And also i checked model performace with 100 ohm load.
can we have webex to understand the proble.
It sees to be you got required information for your original query.
Please create a separate thread for your new query.
