Artix-7 applying power to I/O pins
For the Artix7 XQ7A200T-2RB676I, are there any concerns with applying voltage to the I/O pins when the FPGA is not powered? Currently, we have a power-on setup where multiple discretes at a voltage of about 2.8V are being applied to the I/O pins of the FPGA before the FPGA is powered on. A few seconds afterwards, the FPGA is powered on. The discretes go through a resistor network which limits the current to a maximum of .325mA. Is there risk of damage to the FPGA or is there some sort of input protection of the I/O pins when the FPGA is not powered?
Hi @darlm ,
Unpowered pins still have clamp diodes present that will be forward biased when a pin voltage is applied.
There are two aspects of the device specifications that must be considered when determining if a device could be damaged. For more information refer this AR#34347 .
Hope this helps.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
We are not using a battery on our board, so Vccaux and VCC are both 0V, when the I/O voltages are applied to the I/O pins. Therefore, in order to not violate the (Vcco - Vccaux) spec, we want to keep Vcco at 2.625V max.
So, does this mean that the maximum Vin that can be applied to an unpowered bank in our case, assuming a .43 diode drop would be approximately 2.625V+.43V = 3.055V, to prevent risk of damage to the device?
Community Manager
Community Manager
Hi @darlm
When your bank is unpowered the Vcco = 0V, therefore the Vin which is recommended to be Vcco + 0.2V = 0 + 0.2V = 0.2V
Therefore when the bank is unpowered the Vin should be below 0.2V.
The Absolute Max rating for Vin = Vcco + 0.55V = 0 + 0.55V = 0.55V, when the bank is unpowered that absolute max Vin should be 0.55V.
Sandy
Sandy
Community Manager
Community Manager
Hi @darlm
I will try to write a more complete answer here.
As I said when the bank is unpowered you cannot use the expected max of 2.625V in the Vin equation. Theoretically the Vcco is 0 for an unpowered bank and the Vin becomes 0.2V.
Xilinx in general does not recommend driving I/Os when Vcco in unpowered. When the bank is unpowered and IOs are driven the clamp diode turns on.
As @ddn pointed to  AR : https://www.xilinx.com/support/answers/37347.html
Where you need to consider the current through the clamp diode, Iin has a recommend limit in the datasheet of 10mA per diode with a total of 200mA per bank.
For 7 Series there is the TVCCO2VCCAUX specification that @ddn mentioned. The concern is that powering the IOs can reverse biasing the Vcco before the Vccaux and bring the TVCCO2VCCAUX specification in to be consider.
We also have a specific AR addressing the reverse biasing of the Vcco and how to limit the current to meet the TVCCO2VCCAUX specification.
https://www.xilinx.com/support/answers/45985.html
If you ensure that all specifications are met there should be no issues with long term reliability.
Sandy
Sandy
