Behaviour of FlipFlops if fed by BUFGCE clock
Hello. I try to create a circuit that toggles between one and zero every time a press a push button. I synchronize the input with a slow running clock (slow_clk in the schematic) which runs at 1 Hz. On the left side you see the output of a clock divider (uses a counter and a BUFGCE). I used it because another post recommended to use BUFGCE buffers for clock division. It divides a 5 Mhz clock by 5 Million produce a one Hz output. It works: I output the clock on a led pin on my evaluation board (basys 3) and see the led blinking at a rate of one Hertz.
But I'm able to toggle between 1 and 0 on the complete high phase of slow_clk. I expected the circuit to only toggle the value of the tmp_reg (dout) on the rising edge of slow_clk. Because these flip-flops should be edge triggered. This behaviour only occurs if I use a BUFGCE. If I just use toggle register instead of a BUFGCE the circuit behaves like expected. (Toggles only on rising edge and have a delay of 2 clocks). This circuit toggles everytime the clock is high (without any delay) Do you have any idea why this happens?
Re: Behaviour of FlipFlops if fed by BUFGCE clock
Does it work in simulation?
Can you share the rtl code you use to do this?
What chip does your board have on it ?
does that chip support the BUFGCE_DIV ?
