Can I use GTX for 250Mbps line rate?
We have a project whose architecture is one core board and N terminal boards. There are several serial data lines between the core board and terminal boards with a line rate 250Mbps.
The current design bases on Lattice's solution. We want to choose a Kintex-7 deviece to update the core board. But I know the lowest line rate of GTX is 500Mbps. Is there any method to support 250 Mbps line rate?
Thanks a lot.
回复: Can I use GTX for 250Mbps line rate?
hi @adrian7
we can do oversampling to support lower line rate.
please refer to the example here.
https://www.xilinx.com/support/documentation/application_notes/xapp1240-k7-us-clk-data-recovery.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp1249-smpte-sdi-interfaces-7series-gtx-transceivers.pdf
https://www.xilinx.com/support/documentation/application_notes/xapp875.pdf
Boris
Re: Can I use GTX for 250Mbps line rate?
Hi @adrian7,
I believe your looking  for work around for GTX to work  at 250 Mbps which has specification in datasheets saying 500Mbps is supported lowest line rate,
unfortunately  there is no work around  since the GT wizard does allow us to configure GTX as show in below figure , this is because as per  specification and transceivers are design to support the line rate above 500Mbps on-wards , hence you cannot use the GTX for lesser line rate of 500Mbps .
Chandra
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
hi @adrian7
Boris
Thank you, Boris.
Oversampling may be a good solution. We will try it.
Do you believe our Kintex-7 will be compatible with Lattice ECP3 at 250Mbps SerDes?
yes, i believe K7 can be compatible.
you can refer to our datasheet and theirs to check the compatibility.
