prakashdrj
Characterizion of 7 Series GTX
Hello All,
I am working on custom protocol, which has 5 GT/s. I feel that whatever parameter generated by Wizard not fulfil the requirement so want to change it.
Is there any method or algo to do so? I have already used the parameters as per UG746.
How can I use eye scan/sweep to determine the parameterization of GTX?
Prakash
venkata
Use IBERT and run eye scan with your application data. This helps to know the eye opening after the equalizer inside the GT receiver.
balkris
check this ARs
http://www.xilinx.com/support/answers/60024.html
check this document as well
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug908-vivado-programming-debugging.pdf
Thanks and Regards
Balkrishan
venkata
What is your requirement? How do you confirm if the requirement is fulfilled?
prakashdrj
@venkata @balkris
I have used parameters as generated by wizard it self.
I am observing bit loss after some interval, then switched to IBERT and concluded that BER with that generated parameters are not giving required BER, required one 10^-12.
How can I obtain those valid parameter valuation?
Prakash
venkata
Check if the refclk you use meets the required phase noise mask as mentioned in AR#44549
http://www.xilinx.com/support/answers/44549.html
Please try to use different values for TXDIFFCTRL, TXPRECURSOR, TXPOSTCURSOR. Check the ug476 for mapping of different values set to these inputs and with the Tx driver voltage and pre/post emphasis levels.
prakashdrj
@venkata,
REF clock has same profile as your pointed AR.
In our case TX side is behaving properly. But RX side we observe the bit loss. Other than ref clock what are the cause of bit loss?
Your help is appreciated a lot.
Best Regards,
Prakash
venkata
