Die id XC4VLX25-10FFG668I
Hi Sir / Mam
Need your help, if you have any idea regarding part no. XC4VLX25-10FFG668I, if their PCN change in die id on the wafer.
Xilinx device look up their was an error to validate the mark lot id.
Hoping for positive response.
Glenn
Community Manager
Community Manager
Re: Die id XC4VLX25-10FFG668I
Hi glenn.arguil@converge.com
You can the Customer Notifcations here : https://www.xilinx.com/support/documentation-navigation/silicon-devices/mature-products/virtex-4.html?resultsTablePreSelect=xlnxdocumenttypes:Customer%20Notices#documentation
If there is a query relating to the Lot ID or Device marking I would suggest you asked your Distributor.  You should purchase devices from the Authorized Distribution partners then when you have these questions you can ask your distributor : https://www.xilinx.com/about/contact/locations.html?categoryPreSelect=Authorized%20Distributors
Sandy
Thanks Sandy, The parts were rejected
