GTX's TX/RX I/O ports assignment
I am using GT wizard example. Here I modified the exdes.v code, after modifing the code TX/RX are no longer remaining differential pair. And also I'm unable to assign to their I/0 ports. Where am I going wrong?
And also I couldn't able to assign TX_polarity port to push buttons.
Here I have attached my exdes.v file and snapshot.
Check lines 86-89 and 306-322.
Thank you
Re: GTX's TX/RX I/O ports assignment
txp/txn and rxp/rxn are the output/input of GT block. You cannot implement logical functions on this signals. You will need to implement any functionality at the parallel data side of the GT block.
I understood that, we can not use the GTX/mgt pins of the Transceiver as GPIO.
Can I connect the txp/txn to rxp/rxn pins for loopback for production quality testing ? is there any design restriction?
please confirm.
Devraj
There is Near end PMA loopback option to route the serial data going out from txp/txn to rxp/rxn. The loopback happens internal to the device.
Yes it it possible to do external cable loopback to connect txp ->rxp and txn -> rxn
Refer Loopback section below doc for Transceiver internal loopback options
http://www.xilinx.com/support/documentation/user_guides/ug476_7Series_Transceivers.pdf
Satish
