Genesys2 have Close to 16 Mbits of fast block RAM (up 7x)
Hi all,
"Genesys2 have Close to 16 Mbits of fast block RAM (up 7x)" what is the meaning of this sentence?
Any comments on this topic will be very helpful.
Thank you
Rappy
@rappysaha,
Check out my answer to your same question on the Digilent forum.  I think you'll find a more detailed explanation there.
Dan
Advisor
Advisor
I believe it's saying that there's 7x as much block RAM as on the Genesys 1 board.
Thanks for reply.
That means each block Ram has 16Mbits space and total block RAM size will be 7*16= 112 Mbits (I can be wrong)??
Rappy
@rappysaha,
Dan
Thank you Dan. This is really what I wanted,
Rappy
